ECU & Instrument Cluster Replacement
Old Jul 29, 2019 | 12:33 PM
cammyr01's Avatar
Question ECU & Instrument Cluster Replacement
Hello all,
Is there a write up for replacing the ECU & Instrument cluster, 2001 Disco II? I searched and am not finding anything. Hoping this may be something I can tackle with a little bit of help :-)
Thank you!!
Old Jul 29, 2019 | 05:16 PM
Llamasayswhat's Avatar
The repair is very straight forward in terms of repair difficulty, it is just remove and replaced, but you will need a high level scanner(Autologic) to pair the cluster and ECU to the BCU after repair.
Old Jul 30, 2019 | 02:23 AM
JUKE179r's Avatar
Originally Posted by Llamasayswhat
The repair is very straight forward in terms of repair difficulty, it is just remove and replaced, but you will need a high level scanner(Autologic *or Nanocom) to pair the cluster and ECU to the BCU after repair.
Fixed that for you.
Old Jul 30, 2019 | 02:54 PM
cammyr01's Avatar
Uh Oh, now you have me thinking perhaps I need to replace the BCU vs. ECU.
Old Jul 30, 2019 | 07:05 PM
GCBurke's Avatar
If you can find a matched set (cluster , BCU and ECU) it can be done without a scan tool. Be sure its correct of your truck ....SAI or non SAI. After swapping switch the ignition to the on position for 15 min prior to starting the truck.
Old Mar 24, 2022 | 10:10 AM
muffin man's Avatar
Default ????/
program ecu and bcu
if it is only to install and put again in another truck exactly the same, I have simply been informed that you only have to wait 20 minutes for the IDM to be configured (in case the complete fuse box is not changed too)
Old Mar 24, 2022 | 12:22 PM
Best4x4's Avatar
I've never had the IC, & BCU ever sync up by leaving the key on. With a Nanocom you can sync a lower mileage cluster to the BCU or vise versa & it will go with whatever unit has the higher mileage. You can also simply just turn off the ODO flashing via Nanocom as well without syncing anything.
02DiscoFam
Sep 19, 2023 05:46 PM
msm15
Mar 24, 2022 02:11 PM
Bradartigue
Jul 13, 2018 11:31 AM
Jst4fun
Oct 20, 2017 09:52 AM
Sabas79
Range Rover Evoque
Mar 1, 2016 11:15 AM
