eka code?
Old Jun 13, 2021 | 08:24 AM
roverrichard's Avatar
7th Gear
Default eka code?
i have a 1999 disco 2
the engine appears to have gone into lock mode
the remote on the key will open and lock the doors
but the red alarm light on dash stays blinking fast and slow
and the hazard/ 4 ways will not stop
but the engine will spin over but not start
can any one help
i have tried the 1515 eka number
dont know the original one
oh its a td5
File Type: txt
New Text Document.txt (350 Bytes, 50 views)
Old Jun 13, 2021 | 10:15 AM
JUKE179r's Avatar
I’ve had long time arguments online with Disco 2 Td5 owners that the 1515 EKA code won’t work for their European Disco 2s.
You have to get a Land Rover dedicated diagnostic tester to learn the specific EKA code from their Disco 2 BCU.
Old Jun 13, 2021 | 05:06 PM
7th Gear
didn't work for me
have to see who can do it near me
ta though
Old Jun 14, 2021 | 09:55 AM
WaltNYC's Avatar
The hazards blinking continuously makes me suspect that they inertia switch needs to be re-set.
Old Jun 18, 2021 | 04:40 PM
7th Gear
Default inertia switch
where would i find the inertia switch,
and would i be able to reset without a computer?
Old Jun 18, 2021 | 05:16 PM
Harvlr's Avatar
Under the bonnet on the firewall right side. The button on top of it needs to be pressed down.
Old Jun 18, 2021 | 05:17 PM
Harvlr's Avatar
Just push with your thumb. No computer needed.
Old Jun 18, 2021 | 06:14 PM
7th Gear
thanks i didn't know about that
am fitting a new battery in morning
so will try it then
Old Jun 20, 2021 | 04:41 AM
7th Gear
so will try it then
tried it but no difference
Old Jun 20, 2021 | 12:32 PM
mln01's Avatar
Where are you located?
The fact that "the engine will spin over" indicates to me that it's not a typical immobilization situation. When I was sorting out an immobilization problem earlier this year on my truck, the starter would not engage when I turned to key to Position III.
It is odd that the red light in the instrument cluster continues to flash, and the hazards continue to flash.
