Electric brake contrller for 2002 disco II
Old Aug 10, 2021 | 06:04 PM
MKOS's Avatar
Default Electric brake contrller for 2002 disco II
Good day everyone
Have a 2002 disco II with only the flat 4 wire. I would like to add a electric brake controller so I can use my utility trailer with electric brakes.
Anyone have an luck or direction in sourcing and installing one. Nothing in literature. U-Haul claims they can do it
Cheers
MKos
Old Aug 12, 2021 | 11:05 AM
Xanthro's Avatar
Originally Posted by MKOS
Good day everyone
Cheers
MKos
A brake controller will not work with the 4 wire setup as there is no power to the brakes. Which is the blue wire. You'll need to upgrade to a 7 pin, wire two of the additional wires for power to the battery and the blue wire to the brake controller and the brake controller to the battery, ground and brake pedal wire that lights you bake lights.
I'll be installing a new one in a week and will film and then post the video on YouTube so you can see how it's done.
Old Aug 12, 2021 | 11:13 AM
mollusc's Avatar
The utility connector behind the right tail light should have all of the necessary connections. All you have to do is source a harness that goes from the LR connector to a 7-pin.
Old Aug 12, 2021 | 01:25 PM
jastutte's Avatar
here's some info that might be helpful.
Old Aug 12, 2021 | 06:25 PM
Pete C's Avatar
I have everything you need. I had bought it for my 04 but won’t be using it.
PM me if interested.
jmaddox82
Mar 29, 2021 07:17 PM
Lori Ranocchia Gilhooley
Jul 15, 2020 12:56 PM
Andythelandy
Jul 15, 2020 12:55 PM
alfa63
Jan 7, 2020 12:08 AM
gmutis
Jun 30, 2006 07:45 PM
