Electric CDL
Old Feb 28, 2011 | 01:11 PM
drowssap's Avatar
Default Electric CDL
I tried a search but had no luck, has anyone managed to engage the CDL electrically, using motor or soliond. These shifter kits are quite pricey, I thought I found an elec. kit but the company no longer makes it. They replaced it with a mechaical lever runing thru the trany hump into the passenger side compartment.There was a disco I shifter on Egay for $25 but when i asked for the linkage it suddenly went to $160.00. Dont get me wrong $160.00 isnt bad if its a bolt-in but i still have to modify it to fit. I'm sure someone must have at least tried electrically?
Old Feb 28, 2011 | 01:21 PM
Bundu's Avatar
Banned
You can buy a 12V actuator for about $75, but then you need to build your own rig. I had bounced this idea off an engineer friend over some beer and a BBQ and we both came to the conclusion that a mechanical system would be better. This weekend I saw a simple cable and lever shifter mounted to the hump that seems to be easy build. More beer and BBQ to follow....
Old Feb 28, 2011 | 02:06 PM
Snafu / Disco Fries's Avatar
I can supply some beer and BBQ if you figure out an easy and cheap build!
Old Feb 28, 2011 | 02:17 PM
mwindth's Avatar
I want one of these: http://www.amv.com.au/SeriesIIDifflock.htm
Old Feb 28, 2011 | 02:33 PM
jkid's Avatar
I seem to remember Disco Mike saying that he has one or has seen them installed and it works great. If you search some older posts you might find them. I'd check with him for sure.
Old Feb 28, 2011 | 08:48 PM
Rearden Steel's Avatar
Originally Posted by mwindth
Interesting............that is a window lift motor and I seriously doubt it is impervious to water and mud. Window lift motors are meant to be in the doors where they stay dry. They are not generally sealed units.
The company I work for make gear motors.......small ones.........
My 04 and 96 already has the CDL so I have not given this much thought..........guess I will have to take a closer look.
Old Feb 28, 2011 | 09:50 PM
mwindth's Avatar
from site: ..."The electric motor is fully water proof and once activated has no power connected, so cannot burn out or overload, the motor also has an auto cut out so that even if the actuator switch stays depressed the unit will automatically shut off to eliminate any possible damage to the electric motor. "...
Old Feb 28, 2011 | 10:09 PM
tweakrover's Avatar
electronic + rover = headache
Old Feb 28, 2011 | 10:11 PM
Bundu's Avatar
Banned
I tend to agree, why add to the potential problems.
Someone else was thinking about this as well http://www.landroversonly.com/forums...ol-20-a-49551/
Old Feb 28, 2011 | 10:40 PM
mwindth's Avatar
tweakrover and Bundu...normally I would agree, but check out these threads...see both of jycsalas's write-ups:
CDL - Center Diff Lock
Cdl kit install instructions
04 CDL Shifter Installation Video
on the AMV Center Diff lock actuator (CDLA): https://landroverforums.com/forum/sh...ad.php?t=26352
Here as well: https://landroverforums.com/forum/sh...ad.php?t=27773
