Electric Cooling Fan Issue...
Old Jan 14, 2013 | 04:07 PM
CANAMDiscovery's Avatar
Default Electric Cooling Fan Issue...
Should the electric cooling fan (in front of the radiator) spin freely if I reached in with a long screw driver and attempted to turn it manually?
Mine would not budge.
I assume the electric motor is jammed up?
Thanks in advance,
Brett
Old Jan 14, 2013 | 04:12 PM
94svt50's Avatar
Its locked up and the fuse to it will also be blown. Time for a new fan.
Old Jan 14, 2013 | 04:16 PM
Thanks,
I have been researching and figured that was the issue.
I will start looking around. It is sub zero in Denver so I assume there won't be a real urgency to put one on.
Old Jan 14, 2013 | 04:28 PM
94svt50's Avatar
Should be good until a/c weather. Most drive around for along time without knowing about seized fan.
Old Jan 17, 2013 | 08:23 PM
Sure enough...the 40A fuse is blown as well.
Old Jan 24, 2013 | 12:21 PM
I was going to take advantage of the warmer weather here in Denver and remove the cooling fan. I do not have a new one yet.
Questions and concerns:
I assume, being that the fuse is blown as well, that there is no power going to fan.
I will not cause some electrical circuit issue by removing it and driving.
Can these fan motors return to life with a good cleaning and oil? Curious if anyone has tried. Is it a sealed unit?
Part of the reason for removing it... is to have a day for attempting what may be the impossible...cooling fan resurrection, before ordering a new one.
Old Jan 24, 2013 | 12:37 PM
drowssap's Avatar
you should have no problem running without it this time of year.
I dont think it will come back to life, its right out front getting hammer rain and snow.
I replaced my stock fan with 2-12 universal fans, that way I will never be without one.
Old Jan 24, 2013 | 01:03 PM
Figured resurrection was a serious long shot.
By installing a couple universal fans, was there any wiring and mounting issues you came across? Assume you can connect your old plug to the universal wires and wire them in series?
I am one that will more than likely just go back to the stock set up.. plug and play.
Do you see any cooling gains with the 2 fans? Or just piece of mind- which can be even more important sometimes.
Have not researched this yet.
Old Jan 24, 2013 | 08:00 PM
Seems like we have had posts about replacement electic motor.
Old Jan 25, 2013 | 05:54 AM
drowssap's Avatar
there is a post a few months back i did with pictues, it as real easy. I used 2 pieces of 1/4 x 11/2 in aluminum stock from home depot across the top and bottom, I drilled them to match bolts that were already exiting.
Then I mounted the fans directly to the alumium strapping, total cost was less than $75.00.
I wired them (2 wires) into the existing power source for now, I was going to put a seperate switch on one motor, but decided more comstant air was more valuble than having a spare fan.
