Electric fan recommendation
I need to order an electric fan ASAP for Clarkson. We are putting a brand new OEM radiator back in and going with electric fans. Right now, I’m looking at a a 4000 CFM set of fans with less than 50 amp draw, which we can address.
Any quick recommendations or thoughts?
Anyone want to throw out a better radiator I could snag from Amazon?
Mntnceguy (10-02-2021)
The Nissens radiator is a popular OEM-type. Allisport is all aluminum, but expensive and they didn't have any in stock the last time I heard. I am planning on a custom-made radiator from Griffin the next time I have to go into that.
I was thinking about using one of these, measurements seem about perfect, and they come with a PWM controller: https://www.summitracing.com/parts/der-66826
or: https://www.summitracing.com/parts/der-66837
I disagree about no MPG or power gains. I have historically noticed a roughly 1mpg gain switching to an electric fan.
I like using these, but they're getting a bit harder to find. They work killer. Tons of CFM because they have to pull through those tiny Ford grilles. Can usually be had for around $75 or so, and the shroud is generally built in.
The biggest cooling advantage is that you can get max CFM from the electric fan while at idle and completely turn it off while cruising on the freeway. There's plenty of reasons why so many OEMs are now using electric fans.
The following 3 users liked this post by CaptainAaron:
I have heard that this fits with minor modifications on the factory rad: https://www.summitracing.com/parts/der-16927.
