electric fans....anyone running these, particular ones?
Old Jan 8, 2015 | 09:23 AM
  #21
dusty1's Avatar
Followed that. Agree
Old Jan 8, 2015 | 09:36 AM
  #22
drowssap's Avatar
are you going to replace the ac compressor with an electric one to save all those power robbing ponys too.
Old Jan 8, 2015 | 09:45 AM
  #23
dusty1's Avatar
My research tells me it will be a less efficient cooling system. I don't think I will toy with that.......I like air conditioning too much
Old Jan 8, 2015 | 11:22 PM
  #24
dr. mordo's Avatar
I am definitely curious to see how this works out.
Old Jan 9, 2015 | 08:28 AM
  #25
R32's Avatar
R32
Hi
I've installed LS electric fan with modified shroud with Volvo 2 speed relay and via coolant hose below tstat temp sensor for the past 5 months. Works pretty well for me. Better fuel economy for sure. Will post pic over the weekend.
Old Jan 9, 2015 | 08:35 AM
  #26
dusty1's Avatar
I've been on business trip, in Atlanta. the fan set up was here when I got home. I will mess with it this weekend and give a "whats up" with it.
Old Jan 10, 2015 | 05:17 AM
  #27
Dan7's Avatar
https://landroverforums.com/forum/discovery-ii-18/electric-fan-install-52940/
Old Jan 18, 2015 | 12:11 AM
  #28
dusty1's Avatar
so this is the skinny on the out of box set up
hardware looks great. fans are pressed and the shroud is well built. smoothed edges and all. I received 2 temp senders (1 fin stabber and an alternative direct tap) I am not using either, but the threaded sender is a smaller than normal size. I had plenty of length on my wires, both to and from the supplied relay. I did not receive a controller (could have misread the description, I will check on that tomorrow) didn't need that either. from the time I opened the box till the time I had it all hooked up was about 20 minutes. pull tabs for the mounting and some cute little crimped fasteners atop the radiator, made that a 5 minute set up. 10 for me....I couldn't find my fan wrench. coverage of the fan leaves 1.25" of bottom radiator uncovered. I tested both fans and all is good. wiring was simple, I had to reference the instructions to determine that there is a wire for the fan clutch. (again, didn't use that) if I am building head pressure, I will hook it up, but I am looking for simplicity in an already rat nested electrically dominant set up. I plan to real world test tomorrow, it will be in the 60s here (I think......texas, so it may have changed to - 10 by now) but all in all the product looks solid. I will give it a go, over the next few, and report back.
Attached Thumbnails electric fans....anyone running these, particular ones?-dsc_0092.jpg   electric fans....anyone running these, particular ones?-dsc_0094.jpg   electric fans....anyone running these, particular ones?-dsc_0096.jpg   electric fans....anyone running these, particular ones?-dsc_0099.jpg   electric fans....anyone running these, particular ones?-dsc_0100.jpg
Old Jan 18, 2015 | 09:01 AM
  #29
Looks good, but could I borrow a hose clamp it looks like you have a few spares in there.
Old Jan 18, 2015 | 09:14 AM
  #30
dgi 07's Avatar
Interesting. Keep us updated with the operation ( temps, fuel, etc). Want to see the numbers before pulling the trigger on this one. Subscribed.
