Electric Power Steering Retrofit
Old Apr 26, 2015 | 08:15 PM
Alex_M's Avatar
Default Electric Power Steering Retrofit
Ok, so I've never really touched the steering system other than replacing track bar and pittman arm. I know exactly jack about Has anyone retrofitted electric power steering to a Disco? How bad of a job would this be? I'd probably be using junk yard parts off of other vehicles, so any tips for what to look for would be great. My only real reason for doing this is that I'm trying to get as much stuff off of the serpentine belt as I can. I'll be doing the same with electric fans and an electric water pump as well as probably removing the A/C compressor.
Old Apr 27, 2015 | 05:34 AM
dgi 07's Avatar
Hydraulic Electric steering. Where to begin.
It's not goin to be purely electric, you need a hybrid system. It's basically just an electric pump that pumps when needed, so there is also a reservoir and accumulator. The units I work with are way to expensive to justify, and work on CAN, and require a 40 amp circuit. The easiest way I would imagine would be to have a small pump and accumulator with a pressure switch that operates to tell the pump to kick on.
Old Apr 27, 2015 | 01:25 PM
slammin_LWB's Avatar
Saturn Ion column.
Then there is a seller on ebay that sells a system to adjust the sensitivity (Saturn Vue ion Chevrolet Equinox ? Electric Power Steering Controller Box ? Epas | eBay).
Install and done.
Old Apr 27, 2015 | 07:16 PM
Alex_M's Avatar
Originally Posted by slammin_LWB
Saturn Ion column.
Install and done.
Looks nice and a good price too. Thanks!
Old Apr 28, 2015 | 05:26 AM
antichrist's Avatar
I take it you don't off-road much. Personally, I'd hate to have to drive in the boonies with no power steering.
Old Apr 28, 2015 | 05:49 AM
dgi 07's Avatar
I'm gonna have to disagree with you there.....
electric power steering is 8 times easier to turn. There is literally no effort when it's boosted all the way up.
The only reason I would say no to electric p/s on an offroader, is that there is a major lack of feedback to the wheel. Kinda "vague" for lack of a better term.
Old Apr 28, 2015 | 08:27 AM
Alex_M's Avatar
Hmm, I didnt think about that. Would it increase it if you just turned it down a little? I guess you could do that with the kit listed. Like I said, I'm really in foreign territory here. 90% of the time I'm removing electronics in place of older manual technologies.
Old Apr 28, 2015 | 08:44 AM
I came across that kit in a post somewhere where it was retro'd onto a Unimog....so I think it can handle a Rover just fine.
Also, I offroaded my RRC with 33"s and no PS (With the BMW M52 engine swap) and it wasn't difficult. I look like Popeye now though.
Discovered the linked kit and Saturn Ion method when researching ways to retro PS into the RRC....ended up making the OE fluid system work with some custom lines and a bracket.
Old Apr 28, 2015 | 09:14 AM
antichrist's Avatar
And more points of failure.
As for easier to turn, I guess if you have a disability and need zero effort that's a different story.
I've never found myself thinking the PS pump not up to the task with 32" tires.
But everyone has different priorities. When I'm mulling over how to do something mine is (especially for off-roading) KISS, which goes back to the more points of failure.
Guest66
Defender
Jun 3, 2007 09:12 AM
ambishop
Feb 9, 2007 03:07 AM
stanigu
Jan 10, 2007 06:31 PM
Disco Alan
Jul 11, 2006 06:33 PM
modelwerks
Sep 3, 2005 11:32 PM
