Electrical Diagram Question
Old Feb 6, 2020 | 07:33 PM
greisinb's Avatar
Default Electrical Diagram Question
In the electrical diagram pdf under the heated elements (such as mirror or the rear window) it has a current indication.
1) Is this how many amps that component is supposed to draw? 1 amp times 12 volts equals 12 watts, which hardly seems like enough to defrost the rear window.
2) The rear window and each of the wing mirrors are listed at 1 amp but they all run through a 30 amp fuse, that seems way to high if they are only supposed to draw 1 amp each.
Thanks for any insight or confirmation (I’m trying to troubleshoot the heater elements, if you can’t tell!)
Old Feb 6, 2020 | 07:51 PM
mln01's Avatar
What do you see in the wiring diagram that indicates amps? Other than the size of the fuse, which is 30 amps?
Old Feb 6, 2020 | 09:16 PM
greisinb's Avatar
The size of the fuse is what I’m referring to. I don’t know if there is any standard regarding the correct size fuse but 30 amps for a 3 amp (supposedly) circuit seems way too high.
Ultimately, and I apologize for not phrasing it clearly on the first go around, what I want to know is how many amps should be running through these circuits? My rear screen takes forever to de-fog. I’m planning to measure the current and want to know what I should be expecting.
Old Feb 6, 2020 | 09:20 PM
greisinb's Avatar
Alternatively if someone with a well functioning rear defroster wants to undo the terminals and measure the resistance across the grid, that would work for me to!
Old Feb 7, 2020 | 03:48 AM
JUKE179r's Avatar
Any electrical heating source is going to have high amperage.
The Disco is old. My rear defroster takes a while to work also. Throw a towel over the windows at night or park it in a garage/overhang.
Old Feb 7, 2020 | 09:32 AM
Externet's Avatar
Surprisingly, I see "1 AMP" in the right side box for "Heater element rear screen"
I would prefer to see "x Amperes"; but if the british are also into mutilating words, well, let them have it their way.
Old Feb 7, 2020 | 09:53 AM
mln01's Avatar
Originally Posted by greisinb
... if someone with a well functioning rear defroster wants to undo the terminals and measure the resistance across the grid, that would work for me to!
Maybe I'll do that this weekend. I could also connect the multimeter in series and measure the amperage directly.
Damn. I overlooked that.
Old Feb 7, 2020 | 10:37 AM
greisinb's Avatar
That's exactly what is causing the confusion for me, what else could that 1 amp mean other than "this element is supposed to draw 1 amp at a 12v nominal voltage"? If you look at the heated mirrors they also say "1 amp" in the little box, that's where I got the circuit total of 3 amps from.
Old Feb 9, 2020 | 01:44 PM
mln01's Avatar
Okay, here are the results.
I connected the multimeter in series in the heated rear window circuit, started the engine, pressed the switch and read the current draw. It was drawing about 9.25 amps.
I also connected the multimeter across the two heated rear window connectors to read resistance. The reading was 1.7 ohms.
Hope this helps.
Attached Thumbnails Electrical Diagram Question-photo449.jpg   Electrical Diagram Question-photo424.jpg   Electrical Diagram Question-photo945.jpg
Old Feb 9, 2020 | 01:49 PM
greisinb's Avatar
Thanks! That makes sense to me, a 9.25 amp draw is way more reasonable than a 1 amp draw, so I'm probably misinterpreting the electrical diagram manual. The resistance reading is useful too as I can double check to make sure that all of my traces are intact (more traces, less resistance, more current- so that should be useful). I already know that I have at least 1 that doesn't work. Thanks again!
greisinb
Nov 25, 2019 04:00 PM
PbdyJr
Feb 24, 2019 12:21 PM
M3g474rd
Jan 27, 2015 03:39 PM
southen96disco
Dec 7, 2012 09:49 PM
chriss2s
May 29, 2012 06:51 AM
