electrical help please. .
Old Jan 22, 2015 | 10:56 PM
cavery's Avatar
5th Gear
Default electrical help please. .
2004 disco 4.6l.. problem is p0130, p0150.. both b1s1, b2s1 shows (on scanner) 0.01v ish. (Lean) both b1 and b2 s2 steady at 0.90v(rich) . Car is running rich.. both s1 o2s new and correct. .doubt short in wiring since both s1 o2s show same and separate wires to ecm.. suspect ecm failure. . What I need to know is with key on engine off and b2s1 o2 disconnected what voltage is on signal wire on engine side of harness (from ecm). At ecm connector c0635 pin#16.. help please. .thanks. .
Mountaingoat1975
Apr 10, 2014 09:52 AM
Cleverjoe
Nov 5, 2013 09:22 AM
smoker
Apr 16, 2012 11:32 PM
ATLDisco
Nov 12, 2009 05:20 AM
jbremser
Dec 26, 2008 03:07 PM
