ELECTRICAL PROBLEM 2003 DISCO II
Old Apr 27, 2008 | 09:15 AM
ROLLOVER's Avatar
6th Gear
Default ELECTRICAL PROBLEM 2003 DISCO II
Greetings all. I am new to the Rover Forums but not new to Land Rover vehicles as this is my fourth. I am not sure ifI have a bad bulb,dirty socket or bad ignition switch. When I turn on my headlights all of the brake lightscome on. When my headlights are off and I depress my brake pedal, the dash and front amber signalsilluminate. I have played around with this and can find no reasonable answer. DISCO MIKE??????
Old Apr 27, 2008 | 09:17 AM
Default RE: ELECTRICAL PROBLEM 2003 DISCO II
Sorry, I really don't even know where to go with this issue.
Old Apr 27, 2008 | 09:21 AM
You either have a short or a bad ground.
Old Apr 27, 2008 | 12:29 PM
ROLLOVER's Avatar
6th Gear
I have owned this Rover almost one week and was purchased from Land Rover Newport Beach. I am beginning to see why I am having electrical gremlins. I inspected the car and have evidence that the car was hit rather hard as the rear quarter panel was replaced and the exhaust sytem has a crimp in it. The quarter panel is unpainted on the inside and has no protective undercoating. There are numerous areas of overspray as well. Dealer claims ignorance. The car was not purchased "as-is" as I purchased an extended coverage plan. Do you feel one could make a clear case for a buyback?
Old Apr 27, 2008 | 12:38 PM
Since you have only had it a week, I would say yes. Most states allow up to 30 days or 1000 miles, I dont know about CA, but I would take it back Mon.
If they bought it from acution then I can see why they knew nothing, if they took it in on trade they should have ran a Carfax report and they would have sold it at auction.
If they are the ones who fixed it then they flat out lied to you and they did a sub-par job at the repairs and should be ashamed of the work that they did.
Old Apr 27, 2008 | 12:42 PM
Will depend on the state and county you live in. Some district attorneys state a discloser needs to be included if a vehicle has been wrecked.
Contact your local D.A. office tomorrow and talk with them before you talk with the dealer.
Old Apr 27, 2008 | 09:54 PM
roverguy7's Avatar
you need to check your brake light bulbs. if you have a single filiment bulb where there should be a duel, youre in effect shorting out your tail lights to your brake lights.if there are 2 contacts in the bottme of the bulb holder, and only one on the bulb, its wrong, replace it with the right bulb and you should be good
[/align]
ctsigler
May 6, 2015 02:56 PM
steve@flashtech
Jul 28, 2010 11:34 AM
topfrog007
May 29, 2009 12:14 PM
jcarr
Feb 4, 2007 07:14 PM
IJDICAO72
Jan 24, 2007 09:22 AM
