Electrical Problem. Need help
Old Aug 2, 2005 | 12:52 AM
My98disco's Avatar
7th Gear
Default Electrical Problem. Need help
My 98 disco's RPM gage works on and off. When it's working, the horn and rear windows work. When it doesn't move, horn does nor honk and the rear windows don't roll down. and If they are down, they don't roll up.
Pretty crazy. Any suggestions?
[IMG]local://upfiles/1157/1DBC6C3DF62F47A2871E21A8CEB40A37.jpg[/IMG]
Old Aug 4, 2005 | 01:21 AM
duboff's Avatar
Default RE: Electrical Problem. Need help
not quite as crazy as you think. I think there is a weak relay in the electrical system. check the fuse diagram in the owner's manual and see which one/ones have effects on the systems you are have problems with. the other thing to check is the vehicle grounding points. They can malfunction and cause some funky things. Mine is a 96 disco, so I won't tell you where they are on your vehicle, but there maybe others that have had similar problems. gotta love a rover. duboff
VHOA
Feb 27, 2011 03:37 PM
richardcoolj5
Jun 4, 2009 09:45 AM
VikingDiesel
Dec 30, 2008 05:17 PM
jbremser
Dec 26, 2008 03:07 PM
disco ii hse
Aug 20, 2007 02:47 PM
