Electrical Problems
http://www.green-oval.com/joomla/ind...&Itemid=29
Download your model, which is a DI, this IS THE shop manual for Rovers.
Installed a new IAC that I picked up at Advance. Still didnt do this trick. WOnt hold an idle...I srpayed engine starting fluid several times and each time it cranked and came to life at ab 2 to 3k rpm but then dies, didnt hold an idle. any thoughts.
Downloading the RAVE CD now. when it finishes downloading do i open it with the alcohol 120 program?
Thanks so much for your help, it is greatly appreciated.
yes sir, with carbuerator cleaner. what length should i adjust the IAC to, the box from Advance said 1 1/8th inches. it was a GP Soreson 21774 779-10153. got the truck to hit ab 2k rpm with engine starter but wud only do that when engine starter was sprayed in intake. wudnt idle on its own.
Start it and hold your foot on the gas pedal, as long as you keep the RPM above 550 it will run. No need to use starting fluid.
As for how to adjust the steeper motor, I have no idea.
Definately tried that, i cant keep it above 550 no matter how hard i try. is there any chance it might be ther fuel pump relay? is that located in the engine on the left fender?
Thanks so much for yur help, mv
good stuff thanks for tracking with me thus far. me and my dad are trying to tackle this thing. where is the schrader valve located in the engins. i have the RAVE CD downloaded, is it located on there?
Thanks so much, mv
Thanks so much, mv
good deal I'll check that out, quick question. how can we know which fuel systemI have. is there a plate somewhere on the rover that says. i dont have my owners manual. tdi, mfi, sfi ormpi? Thanks so much, mv
