Trailer brake caught fire and Burnt my brake harness , brake light itself is still good just the wires . I can’t drive my car home from school to fix it because I can’t get it out of park how can I hot wire the brake light to disengage the lock so I can put it in drive and limp it home
Yeah pull the shifter **** straight up, then gently raise up the shifter bezel, then you’ll see the interlock solenoid, push the little button back and shift it into whatever gear u need. You can leave the shifter bezel off and drive it, just put the **** on and you’ll be set.
It's been awhile but I don't think you need to pull the **** off. Pull the bezel off and it's behind the shift lever .feel around. It's just a little button .
That worked perfectly I just have to figure out where to even start with this wiring , after I drive an hour with no brake lights hazards or turn signals
