Emergency SOS
Old Sep 6, 2018 | 04:49 PM
escott16's Avatar
Default Emergency SOS
Trailer brake caught fire and Burnt my brake harness , brake light itself is still good just the wires . I can’t drive my car home from school to fix it because I can’t get it out of park how can I hot wire the brake light to disengage the lock so I can put it in drive and limp it home
Old Sep 6, 2018 | 04:59 PM
zuke's Avatar
Can you pop the cover off the shifter base and push the release button?
Old Sep 6, 2018 | 05:05 PM
Best4x4's Avatar
Yeah pull the shifter **** straight up, then gently raise up the shifter bezel, then you’ll see the interlock solenoid, push the little button back and shift it into whatever gear u need. You can leave the shifter bezel off and drive it, just put the **** on and you’ll be set.
Old Sep 6, 2018 | 05:08 PM
Ben Matheson's Avatar
Also make sure all those burnt wires are separated then check the brake light fuse. Pretty if that fuse popped it will give those symptoms
Old Sep 6, 2018 | 05:12 PM
escott16's Avatar
Where exactly is the button what does it look like?
Old Sep 6, 2018 | 05:22 PM
zuke's Avatar
It's been awhile but I don't think you need to pull the **** off. Pull the bezel off and it's behind the shift lever .feel around. It's just a little button .
Old Sep 6, 2018 | 05:49 PM
Red5's Avatar
This...
Old Sep 6, 2018 | 05:53 PM
Extinct's Avatar
Button on the left, solenoid on the right. You can just remove the solenoid.
Old Sep 6, 2018 | 06:13 PM
escott16's Avatar
That worked perfectly I just have to figure out where to even start with this wiring , after I drive an hour with no brake lights hazards or turn signals
Old Sep 6, 2018 | 06:55 PM
redwhitekat's Avatar
A good reminder to always carry basic tools and spare fuses for situations like this
