emission codes
Old Aug 9, 2010 | 06:06 PM
bluerover95's Avatar
Default emission codes
2001 D2 SD
service engine soon lamp up
OBDII says codes
PO1414
PO1417
What do they require?
DRJ
Old Aug 10, 2010 | 09:17 AM
hilltoppersx's Avatar
they are not emissions codes they have to do with the SAI.
check to make sure the secondary air hose isnt loose, it could be something simple like the little vacuum line is off of the secondary intake. it comes off really easy. If it is on and not loose, then use the system vacuum lines to operate the solenoids. Make sure that they make noise when opening. it is possible that htey are stuck open. It will give a slight whistle but i don't think you would get both codes if that were the case.
Yoops Racing
Nov 30, 2014 10:40 AM
Rick9Plus
Aug 12, 2011 10:11 PM
paris1099
Oct 12, 2010 12:34 PM
Dell
May 1, 2009 08:09 PM
savatage
Feb 12, 2007 07:25 PM
