Engine code (P1448) Evap system Help
Old Apr 27, 2005 | 12:26 AM
Bugman's Avatar
6th Gear
Default Engine code (P1448) Evap system Help
I have a 98 discovery V8 241, 4.0L with 102,000 miles in great condition. Runs great, no problems except the check engine light came on, so I pulled the code and it was ( P1448 Evap system purge valve flow 2 fault ) I reset the engine light and it stayed off for 2 weeks. Then today it came on, so I pulled codes again and it read the same code again. Does anybody have any ideas of what to try or were to start?
thanks for any help you can give
_____________________________
98 Discovery II LE
Old Apr 27, 2005 | 01:20 AM
Bait's Avatar
Default RE: Engine code (P1448) Evap system Help
Most common is purge valve.
rhyslegge
Oct 8, 2011 11:48 AM
joefresso
May 4, 2011 08:31 AM
jason9500
May 12, 2008 01:11 PM
jason9500
May 12, 2008 08:21 AM
Bugman
Apr 26, 2005 12:32 AM
