engine codes
Old Jul 15, 2013 | 08:38 PM
DIIZ's Avatar
Default engine codes
Ok so I just got my check engine light checked and I got these 2 codes. .. no idea what they mean.
P1412
p1415
Old Jul 15, 2013 | 09:02 PM
Don't have the exact info, but they are both for your SAI either as a line leak or a valve leak on both sides of the engine.
Old Jul 15, 2013 | 09:07 PM
ralphobell's Avatar
P-code Description
P1412 Secondary Air Injection System – Malfunction Bank 1 LH (Insufficient SAI flow
during passive test)
P1414 Secondary Air Injection System – Low air flow Bank 1 LH (Insufficient SAI flow
during active test)
P1415 Secondary Air Injection System – Malfunction Bank 2 RH (Insufficient SAI flow
P1417 Secondary Air Injection System – Low air flow Bank 2 RH (Insufficient SAI flow
during active test)
Flow Fault Finding chart
1 Fault codes P1412, P1414, P1415 or P1417 present
2 Insufficient flow detected
3 Is fault present on both cylinder banks?
If 'NO' proceed to step 4
If 'YES' proceed to step 8
4 Vacuum supply – Check for: blockage and/or vacuum line disconnected from SAI valve
5 SAI Valve – Check for: jam / diaphragm leak or blockage
6 Delivery Hoses to SAI Valve – Check for: blockage / leaks
7 SAI Pipes to Cylinder Head – Check for: blockage / leaks
8 Electrical Issue – Check for: Related P code (relay/fuse/solenoid), rectify as necessary and check connectors
9 Vacuum Supply – Check for: Blocked/leaking vacuum lines or correct solenoid operation (open/closed)
10 Delivery Hoses – Check for: Blocked/leaking hoses
11 SAI Pump – Check for: Correct operation using TestBook/T4 or pump blockage/failure
12 SAI Valves – Check for: Both SAI Valves jammed/blocked/leaking diaphragms
Old Jul 15, 2013 | 09:34 PM
Good information.
Old Jul 15, 2013 | 10:52 PM
DIIZ's Avatar
Wow. Thanks for the quick response. I appreciate it.
So how would one go about fixing this problem?
Old Jul 15, 2013 | 11:13 PM
ralphobell's Avatar
Follow the flow chart that is posted.
Old Jul 16, 2013 | 03:50 AM
FlyingZebra34's Avatar
I'm saving that flow chart, did you make that?
Old Jul 16, 2013 | 07:10 AM
ralphobell's Avatar
No, it is from the RAVE.
Old Jul 16, 2013 | 08:14 AM
DIIZ's Avatar
Thanks Again. I'll try to figure that out today after work
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
