Engine coolant?
Old Mar 26, 2007 | 04:47 PM
98DiscoC's Avatar
Default Engine coolant?
After I drive I can smell engine coolant, no leak and it hasn't over heated. Any suggestions??
Old Mar 26, 2007 | 05:08 PM
Aquaholic's Avatar
Default RE: Engine coolant?
If it wasn't leaking you wouldn't be able to smell it.
Check the throttle body coolant hoses.
Old Mar 26, 2007 | 05:36 PM
geoman's Avatar
Smelling coolant from where?--- outside of the vehicle or inside?
If inside, feel the carpeting on the passenger floor board near the center console. If it is wet, you are looking at replacing the heater core. If outside --- look on the drivers side engine valve cover for signs of coolant leakage (green colored deposits on earlier models ---orange on later). This tells you the throttle body heater plate gasketis going, and this MUST be corrected right away.Then get under the vehicle with a flashlight and look behind the exhaust manifolds on each side for evidence of head gasket seepage. Also look around the front timing case cover for evidence, as they tend to develop a leak there when the gasket starts to let go. And last ---while you are under the vehicle, look at the UNDERSIDE of the water pump snout (where the pulley and fan bolt up) for evidence of coolantdeposits coming from the"weep hole" on the aluminum casting.
These vehicles have little tolerance for overheating, so before the summer weather gets here you had better isolate the source of the smell. To do nothing, and just hope ---- is like rolling dice on a Land Rover.
regards,
Geoman
www.eurotekapg.com
Old Mar 26, 2007 | 05:40 PM
May be should go it the coolant system pressure tested and it will show up real quick.
Mike
Old Mar 30, 2007 | 09:04 PM
98DiscoC's Avatar
Thanks Geoman.
I do have some seepage from the head gaskets. I see that on the eurotekapg website there is a head gasket kit, does the kit have everything I need to fix this problem?
Old Mar 30, 2007 | 10:50 PM
You will also need to replace all the head bolts.
I would suggest before you do the head gaskets that you do a good engine flush first to clean out some of the build up that would other wise get in your way.
Mike
Old Mar 30, 2007 | 11:36 PM
greg409's Avatar
RE: smelling antifreeze
I agree, some thing you don't put off - oil, brakes and coolant.
I'd stick my nose on the pass side carpet & smell all over.
Feel for dampness in your carpet(up high, too)
If your heater core is leaking, it could get real bad in a hurry and you could be an hour from help.
Old Mar 31, 2007 | 12:22 PM
98DiscoC's Avatar
Not the heater core, checked that as soon as I found out it would leak inside the truck. Can someone suggest a head gasket kit, I see that www.roverparts.com , www.roverconnection.com and www.eurotekapg.comhas them. Should I by an aftermarket or LR kit?
Old Mar 31, 2007 | 01:32 PM
Get in touch with Geoman, he has the kits and head bolts, might want to consider a new t/stat while you are at it.
Mike
ZMonet
Jun 24, 2016 04:00 PM
Rufflyer
Mar 22, 2015 10:13 AM
sadain
May 3, 2012 09:40 PM
seniordon
Jan 17, 2011 06:45 PM
