Engine/Cooling System Sealers - Yes or No?
Old Dec 21, 2024 | 11:47 PM
nashvegas's Avatar
Dear god no. No no no no no.
Old Dec 22, 2024 | 01:20 PM
Richard Gallant's Avatar
There are block sealers you can use that work, but god the amount work required is nuts. And they are not cheap $40 to $50
  1. Do any head gasket work required
  2. drain and fully flush the engine with distilled water - NOT tap Water
  3. disconnect the engine from the rad, heater core, and any small hoses like the throttle body, and hose on top of the rad. (Or use a sacrificial rad that you are going to toss out)
  4. Remove the thermostat
  5. Route the hoses to allow water circulation
  6. Add the water and then the sealant
  7. Engine up to temp for the recommended time
  8. Complete coolant drain
  9. Pull the frost plugs, drain plug and hoses
  10. Let the engine coolant passages fully dry for 48 to 72 hours longer if in doubt (you can blow heat in to help drying)
  11. Put all the plugs in and do a final flush
  12. Put it back together and hope for the best
Extinct
Apr 3, 2024 07:59 PM
Bulax99
Jan 28, 2019 09:51 PM
lucky139
Mar 10, 2014 10:42 PM
Disco00
Apr 11, 2011 10:15 AM
epeteha
Jun 9, 2008 05:27 PM
