Engine Knocking Disco 2003
Old Dec 18, 2011 | 08:48 PM
SaltyRover03's Avatar
7th Gear
no warranty but the manual states
Engine oil - V8 - North America
Use a 5W/30, 5W/40 or 10W/40 oil meeting
specifications API SH or SJ, having a viscosity band
suitable for the temperature range of your locality.
ill give my insurance company a call and see. I got nothing to loose
Old Dec 18, 2011 | 08:58 PM
5w-40 for the winter and 15w-40 for the summer depending on where you live.
If you live in the south 15w-40 year around.
Old Dec 18, 2011 | 10:55 PM
7th Gear
what is the number of quarts that is supposed to be used?
Old Dec 18, 2011 | 11:51 PM
Change and filter - 6.1 without oil cooler and 6.6 with oil cooler, if you have a cooler it is between radiator and AC condenser, along with the tranny cooler (all had tranny cooler - below VIN 756821 have oil cooler).
Old Dec 19, 2011 | 03:51 AM
7th Gear
they put in 6.5 quarts and claimed that when they got it had a oil overfilled by 3.5 qts. the spark plugs where oil fouled. would the brand of oil they put in matter.
Old Dec 19, 2011 | 04:19 AM
No the brand of oil won't matter for short term use (national brands, etc.), that only controls the "additives" in the oil that alter the cleaning ability somewhat over a long period of continued use.
What color is the oil on the dip stick? If it is red, they put in automatic transmission fluid by mistake, and you will have a valid claim. ATF is much thinner than motor oil, and high detergent. Sometimes people use it as an engine flush. In Detroit test labs, they use it to accelerate wear on an engine being worked on.
Overfilled is interesting. The oil level in the pan is highest when engine is not running, cold. But even then, it is below the level of the bottom of the crankshaft lobes. If 50% more oil was in there, seems like you would have had sluggish performance with crank touching a liquid. You would have noticed a performance change after the oil change to proper level. You would have noticed this on the dip stick on any routine inspection of the truck (weekly is a good rule of thumb).
A bad sign of overfill would be coolant leaking into oil from a head gasket problem. Oil drainers may not have seen coolant in oil (milky look) because they don't stand there and watch it, they open the drain and go do something else. On the other hand, not exactly sure how they determined that they got 9.6 quarts out of it, and certainly there is no 3.5 quart above normal mark on the dip stick.
Old Dec 19, 2011 | 06:54 PM
It sounds to me like what he is saying is that when the dealer first got the truck the engine was over filled with oil.
Then they changed the oil and plugs.
He bought it, drove for 2,000 miles and then this happened.
Either the shop did something wrong or the engine was on its way out when he bought it but the problem had been masked in some way, possibly by the original seller.
Old Dec 19, 2011 | 07:31 PM
A gallon of Lucas will cover up a lot....
jzakary
Sep 10, 2020 10:38 AM
whatismyusername
Aug 18, 2011 12:52 PM
yellowlablounge
Sep 21, 2009 09:18 AM
mellyagaunce
Sep 19, 2008 09:16 AM
tobob1
Sep 11, 2006 09:14 AM
