Engine Miss fires when cold
Old Nov 3, 2009 | 12:36 PM
narleyman63's Avatar
Hope everyone had a wonderful Halloween.
I have also just cleaned the throttle body and Mass Flow.
Old Nov 3, 2009 | 12:46 PM
lipadj46's Avatar
Just a heads up. These particular Bosch MAFs do not react well to cleaning. If you start getting MAF codes in a month or so don't be surprised.
Old Nov 4, 2009 | 08:36 AM
What type of cleaning are you referencing such as spraying and let soak for 10 minutes or just spraying while the engine runs?
Old Nov 4, 2009 | 09:07 AM
Before you do anything else on your truck, check with us first, cleaning that MAF will cost you $230 in a very short while. Our Bosch MAF don't take to being cleaned.
Old Nov 5, 2009 | 12:38 PM
will do - thanks mike
Old Feb 1, 2012 | 06:05 PM
jrover99's Avatar
my discoII has 175000 miles on it how long should a head gasket last mine was done at 94000 miles but I think the truck needs a tune up i smell gas when it is cold and when the truck warms up it is good..Please let me know i really cannot afford to do head gaskets again.. thanks
Old Feb 1, 2012 | 07:33 PM
As long as you keep the PCV clean the head gaskets should last forever.
Sounds like you need a tune up.
Old Feb 2, 2012 | 09:08 AM
Not sure why you are worrying about headgaskets if you are having cold start issues. Sounds like you truck needs some major help, go look at my sticky at the top of this section on major services and consider doing it all, you can not afford to neglect your truck, it will just cost your more in the long run.
If you have any questions on this, PM me your number and I'll walk you thru what to do.
disc0man
Nov 17, 2014 12:37 PM
giboulou13
Nov 1, 2010 07:37 AM
tacomatech
Oct 22, 2008 10:08 PM
nathan214
Oct 21, 2008 06:21 PM
janikphoto
Defender
Mar 14, 2008 01:11 PM
