Engine missing, but no CE codes?
2001 Disco has a miss / rough idle (it's a spare truck I picked up a couple months ago with a bad trans that only goes in reverse). I figure it many just need a tune-up, as it just has two transmission codes (722 / 1884) when I put the scanner on it to read the CE light. No other codes....probably just a standard wires/plugs issue most likely?
transmission codes are very scary. our trucks rarely have problems with the transmission unless the drive shaft drilled a hole thru the side of it....
as for the miss i would start with a tune-up. new 8mm magnecor wires and some bosch +4 plugs.
first i would figure out the transmission problem.
Athana
03-15-2014 01:56 PM
miishmiish
03-08-2006 12:31 AM
