Engine missing, but no CE codes?
Old Apr 25, 2010 | 07:25 PM
blast20's Avatar
Default Engine missing, but no CE codes?
2001 Disco has a miss / rough idle (it's a spare truck I picked up a couple months ago with a bad trans that only goes in reverse). I figure it many just need a tune-up, as it just has two transmission codes (722 / 1884) when I put the scanner on it to read the CE light. No other codes....probably just a standard wires/plugs issue most likely?
Old Apr 25, 2010 | 07:54 PM
hilltoppersx's Avatar
transmission codes are very scary. our trucks rarely have problems with the transmission unless the drive shaft drilled a hole thru the side of it....
as for the miss i would start with a tune-up. new 8mm magnecor wires and some bosch +4 plugs.
first i would figure out the transmission problem.
Old Apr 26, 2010 | 07:28 AM
The 1884 code will go away on it's own after you fix the speed sensor issue.
As for the roughness, I agree, start with a good tune, wires, a can of 44K and some good gas.
shanechevelle
May 3, 2015 09:51 PM
Francopacks
May 14, 2014 09:41 AM
BajaXJ92
Dec 3, 2009 07:43 PM
miishmiish
Mar 8, 2006 12:31 AM
