Engine oil cooler?
Old 06-03-2019, 07:07 PM
Dherna's Avatar
Default Engine oil cooler?
So, 03 Disco2. Looks like there's an oil cooler, but it's not connected. Should I connect? or should I just remove?
Top view driver's side
Left nipple... just sitting there.
Right nipple...
That was weird typing that!
Old 06-03-2019, 11:29 PM
Saturnine's Avatar
Could be either oil or tranny cooler
Old 06-04-2019, 01:09 AM
FlyingZebra34's Avatar
The tranny cooler sits near the bottom of the radiator while the oil cooler is higher and above it. Weird that they just by passed it. They do serve a purpose.
Old 06-04-2019, 02:26 AM
Brandon318's Avatar
Oil coolers are only fitted to vehicles up to VIN 756821. What's yours? That looks like just the ATF cooler... super strange that it's disconnected. You have an auto trans, right?
Old 06-04-2019, 06:31 AM
OverRover's Avatar
ATF Cooler has a temp sensor on the Passenger Side.
Old 06-04-2019, 09:52 AM
Brandon318's Avatar
Where do you find parts schematics?
Old 06-04-2019, 10:00 AM
mollusc's Avatar
that's a page grab from the rave manual. download links are all over the place.
Old 06-04-2019, 12:49 PM
I’d get that tranny cooler hooked up if you cans find good hoses. I wanted to add an oil cooler above mine, but could not find hoses.
Old 06-04-2019, 04:59 PM
abran's Avatar
03's have tranny colors, not all have a temp sensors on them. As mentioned, get that thing connected!
Old 06-04-2019, 07:53 PM
Dherna's Avatar
Okay... so let’s pretend there’s another “cooler” right below that one. That would make this one the engine oil cooler, correct? If that’s the case... remove it or connect it? I’m just asking, because there’s another one below that one.
Quick Reply: Engine oil cooler?
