Engine Oil in Throttle Body
I bought a 2000 discovery II. It had a blown head gasket and sounded terrible so I did not drive it. I repaired the head gasket and drove it about 50 miles. Started checking why check engine light is on and found I had a bad ignition coil. Upon removing air hose between air filter and throttle body I found a lot of fresh engine oil in the throttle body area and more when I removed the upper inlet manifold. I am sure it is coming up from the valve cover indicating blow by. The passenger valve cover has an oil separator in the stub pipe between valve cover and inlet manifold. The workshop manual says there is not an oil separator in the drivers side stub pipe. My experience says rings. The odometer shows 185K and the records I got with the vehicle shows head gasket repair at 100K but no other major work ever done.
When I replaced the head gaskets I removed the plate inside the valve covers and cleaned up the sludge in there. I removed a couple spark plugs before I bought it and they looked well used but they did not indicate oil problems.
Do these engines suck oil up through the valve cover? Has some one found inserting a oil separator in the drivers side stub pipe help remedy this problem?
I do all the work myself. I am giving this rig to my son and he does not have time to repair it so I want to eliminate most of the major problems.
The following 3 users liked this post by Extinct:
