Oil in throttle body
Old Mar 27, 2012 | 12:50 AM
amccullough's Avatar
Default Oil in throttle body
Is it normal to have some oil residue in the throttle body?
Old Mar 27, 2012 | 04:31 AM
No it should be clean. You can buy spray for this purpose. May have been sucked in by clogged oil separator in the right side valve cover. A companion hose is on the left valve cover. Intake varies by engine type fitted. But PCV system is simple. Filtered air flows from MAF side into left valve cover, thru engine, and out oil separator in right valve cover (passenger side). Vac line draws it into pleum where this foul pollution of oily fumes is burned to provide a 0.000056 mpg boost. Pull out the little spiral thing in the valve cover and clean, or shoot some carb cleaner thru it. # 3 in attached drawing.
File Type: pdf
Old Mar 27, 2012 | 05:51 AM
With time and driving, yes it is normal to get a small amount of black residue from oily air that is being sucked up thru the valve cover. When you find this, take a can of carb cleaner and a rag, maybe even a tooth brush, and clean it all pot, this will improve your idle and throttle response.
Old Mar 27, 2012 | 10:50 PM
Thanks guys! I have the valve covers off as I'm doing head gaskets, so I will clean and check everything as advised.
Old Mar 28, 2012 | 04:34 AM
Post pictures as you go along, including celebration when it fires up at the end!
Old Apr 1, 2012 | 07:31 PM
ralphobell's Avatar
Quick question. I failed to notice which way the oil separator was facing when I removed it from the valve cover. Does the flat side with the two small **** insert facing up towards the hose or does it face down towards the rockers?
Old Apr 1, 2012 | 07:42 PM
IMHO either way, it is just a baffle.
DeepBlueWater
May 6, 2019 09:19 AM
nazdackster
Mar 3, 2014 11:36 AM
SenatorPerry
Jul 15, 2013 10:28 AM
bentonrover
May 15, 2011 03:37 PM
Doss
Mar 26, 2006 06:00 PM
