Engine Part Comptability
I'm scouring eBay for a new front/timing cover. I saw one posted that came off a '04 4.6L, which they said would fit my '01 4.0L without issue?
I also saw a listing for a 4.6L cover from a 99-02 Range Rover, which looks the same.
I just wasn't sure which models used the same engine, so that parts could be swapped between them.
the only difference from my understanding was the 03/04 had the brass plugs that block the oil cooler that are removable where you can use them on 00-02
Landys4ever
08-10-2009 01:06 PM
