Engine Part Comptability
Old Feb 22, 2017 | 10:31 PM
robert.juric's Avatar
Default Engine Part Comptability
I'm scouring eBay for a new front/timing cover. I saw one posted that came off a '04 4.6L, which they said would fit my '01 4.0L without issue?
I also saw a listing for a 4.6L cover from a 99-02 Range Rover, which looks the same.
I just wasn't sure which models used the same engine, so that parts could be swapped between them.
Old Feb 22, 2017 | 10:47 PM
Bom2oo2's Avatar
Both will fit your block, P38 Range Rover engine has little cosmetic differences but front cover is not one of them, but you will need to attach filter elbow from your old cover to it, so pick the one that looks best,
Old Feb 22, 2017 | 10:52 PM
OverRover's Avatar
The cover from the '04 is a no go.
Have a look at the pics you want part number: LJR105040 and it does fit different models. Good Luck!
Old Feb 23, 2017 | 12:10 AM
Luckyjayb's Avatar
the only difference from my understanding was the 03/04 had the brass plugs that block the oil cooler that are removable where you can use them on 00-02
Old Feb 23, 2017 | 12:38 PM
shanechevelle's Avatar
Are you looking for a used one or must it be new?
Old Feb 23, 2017 | 04:53 PM
I was looking for a used one. I ended up getting one from a P38, I decided to take a risk with it. I'll keep everyone posted.
Old Mar 11, 2017 | 11:39 AM
For anyone curious here is the front cover from a P38 I bought off eBay and mine with the modified bolts instead of studs. I just need to swap the bits over and reinstall. As far as I can tell they are the same except for the oil filter elbow.
Shiftonthefly1
Mar 13, 2015 01:17 PM
DonRW2007
Jan 6, 2014 09:19 AM
bosshogt
Mar 31, 2010 02:54 PM
traffictech870
Feb 9, 2008 09:26 PM
