Engine Swap Finished! First Fire Went Well.
Old Jul 29, 2010 | 11:40 AM
Bryan H's Avatar
Default Engine Swap Finished! First Fire Went Well.
I finshed swapping an '04 engine into my '03 last night. Took me the better part of 2 full days and 3 evenings to pull the old motor and install the new one (yes, I'm very slow). Also spent one night prior to the swap replacing the front and rear seals, timing cover gasket, and oil pan gasket on the new engine. All in all, a tough be doable swap. The RAVE was priceless of course. The hardest and/or most frustrating part of the swap was the tranny bolts (upper 4). The torque converter access plug was also a pain to get back in (I spent 30 minutes trying to wedge the rubber plug back into the oil pan!).
After intalling the new engine which had sat for at least 1.5 years, I pulled the fuel pump relay and fuse and turned the engine over for about 20 seconds. When I reinstalled the relay and fuse, the engine fired within about 5 seconds. Oil light was on for about another 5 seconds while the pump built pressure. Engine started and ran smoothly immediately. I let it run for about 15 minutes to check for leaks, burn off oil/coolant/PS fluid/etc, and come up to full operating temperature. Went on a very short drive and everything seemed great. No check engine lights yet (old motor did have a light).
I will hopefully get a chance to drive it again today and will give another update.
Old Jul 29, 2010 | 12:30 PM
Bundu's Avatar
Banned
Well done. Yeah your heart always stands still when you start up the first time.
I'm assuming that the PAS hose got sorted out then?
How did you get those 4 tranny bolts in? They were a bitch to get out and I'm not looking forward to that. My engine is on a stand waiting for some final parts to arrive next week, then in she goes hopefully next weekend.
Old Jul 29, 2010 | 01:00 PM
Bryan H's Avatar
It was kind of funny. I found myself subconsciously coming up with little things to do that weren't necessary. I think I was delaying the first attempt at starting the engine (and this was at midnight!).
The hose got sorted out. The problem ended up being the fitting that the hose screws into, which in turn screws into the power steering pump. I swapped the fitting from the old engine and the high pressure hose connected with no problem.
Getting the four bolts back in wasn't quite as bad as I thought it would be. Just do the reverse of the removal process and have the engine dropped as low as possible without the motor mounts installed. It's tedious, your hands will cramp, you might cuss, but it's doable.
Old Jul 29, 2010 | 01:09 PM
Bundu's Avatar
Banned
Originally Posted by Bryan H
you might cuss
You betcha, I was a sgt in the army and have plenty ammo
My wife stays way out of range when I'm working on something, it keeps us happily married.
Old Jul 29, 2010 | 02:49 PM
Bryan H's Avatar
I kid you not, the torque converter plug had me cussing more than anything else. There's nothing like wasting 30 minutes just to stick a rubber plug in a hole. I have no idea what the trick is other than brute force. I lubed it with WD-40, and that seemed to help, but still a pain. Your "ammo" will come in handy. ; )
Old Jul 29, 2010 | 02:59 PM
Bundu's Avatar
Banned
I planned ahead and bought 2 new rubber plugs, my old one's were swollen too far to fit back in.
Old Jul 29, 2010 | 03:05 PM
Bryan H's Avatar
Smart man (and much smarter than this one). You don't need to take the Driver's side out, but it sounds like you may have already handled that one. Whoever pulled the engine I bought had removed them both.
Old Jul 29, 2010 | 08:52 PM
lordmorpheus's Avatar
Bundu - That is the only way to do it. I tried everything under the sun to get my old plugs back in- heat, cold, lubrication, force.... I finally gave up and bought new ones. I was able to get the new ones fully inserted with one hand in just a few seconds.
Old Jul 29, 2010 | 09:10 PM
DiscoWest's Avatar
Congratulations, that is a great feeling to get the motor in and hear it run. Hope it continues to run well for you.
Old Jul 29, 2010 | 09:18 PM
tornado_735's Avatar
Hey Bryan, hats off to you. That's friggin awesome. When we did my swap, it was all fairly easy, although it wasn't without it's bugs. They're all mostly sorted out though!
Here is my first start up (as I was lucky enough to have it on video)
http://www.youtube.com/watch?v=PLVQdO7PD8M
4thefamily
May 15, 2015 11:12 AM
momentum59
Aug 11, 2010 06:36 PM
greenwade
Mar 2, 2010 11:45 AM
sloppyjoe
Dec 15, 2008 11:59 AM
kfx4001442
May 18, 2008 09:50 PM
