Engine Tick and Drivetrain Vibration
Hi Everyone!
I've searched around for some answers on a engine tick and some drivetrain vibration but no luck so here goes-
'04 Disco II, 75,000 miles. Previous service history unknown but sure it was somewhat neglected.
There's a slight but noticeable ticking sound and gets louder with higher rpms, maybe a sticky lifter? I'm about to do head gaskets and thought doing an engine flush then dropping the oil pan to clean the oil pickup screen might help... Any suggestions?
Also, at 75mph there's a very noticeable driveline vibration; everything is smooth up to 75. I've had the tires rotated and balanced and rebuilt/balanced the front driveshaft but have not looked at the rotoflex coupler in the back; could this be my culprit?
Any and all suggestions are greatly appreciated!
Andrew
Andrew
on
Also, count the number of grease fittings on your front drive shaft, if you have 3, you are OK if only 1, get that shaft rebuilt/replaced so you can grease all your u-joints.
As for the head gasket job, Atlantic British is a good place to buy your gasket set, t/stat and new stretch bolts. Also consider replacing your wires with a good set of 8mm wires.
Roto flex could also be the problem.
i have drivetrain vibration as well, there is slight presents of it from 30-60, then goes nice 60-75, and after that - 80mph- A lot of drive train vibration - to the extent that plastic around shifter vibrate... new tires- rotated and balanced, done aliment.
98 Disco I - 90k mi....
98 Disco - 90k mi....
About 3k mi ago I greased rear joint and gave pump or two to the drive-shaft (grasing gun broke - so i gave up on that)
By pulling on the wheels you mean pull on on the top sideways --- to see if it goes in and out?
