Engine ticking while idle and warm.
Old Jun 29, 2011 | 10:37 AM
  #31
photocrimes's Avatar
Originally Posted by DiscoBenjamin
Can you expound on that? And if it is an exhaust leak, would it begin when the truck is at idle and go away when you accelerate? And if you are leaking exhaust, wouldnt that throw Codes of some sort?
Any input would be appreciated.
It usually will still make noise as the engine revs but the sound of the increased rpms and fan noise drowns it out. Depends on the leak too, a leaky exhaust manifold won't always throw codes unless the leak is bad enough to suck air into the system and alter the mixture. Like I said, I couldn't really tell much from the sound on the vid. Just a suggestion. Sometimes you can take a feather or a piece of paper and run it around the exhaust to see if air is being blown out anywhere.
Old Jun 29, 2011 | 11:30 AM
  #32
DarylJ's Avatar
An induction cleaning also tends to make enough smoke to see if there are any exhaust leaks.
Old Jun 29, 2011 | 12:16 PM
  #33
Good idea! Kill two birds with one stone ;-)
Old Jun 29, 2011 | 08:23 PM
  #34
DiscoBenjamin's Avatar
That is a great Idea, I will do that this weekend and reply back. Great idea.
Old Jun 30, 2011 | 04:33 PM
  #35
UProver's Avatar
3rd Gear
I have that damn tick too. Only mine quiets down after warming up but never goes away.
Old Jul 2, 2011 | 12:57 PM
  #36
GARovee's Avatar
Ditto. Mines a lot louder when the engine is cold. Gets pretty much unnoticable after its good and hot.
Old Jul 4, 2011 | 04:35 PM
  #37
bentjeep67's Avatar
03 with mystery tick here..i love this truck but im heading to Seattle from Georgia next month,hope we can figure it out soon! I dont belive this noise is the sleeves,im wondering if its an oil gally that is partially blocked..when you rev the motor it pushes more oil past the block? im going to do a motor flush here..with a cocktail of sludge busters..mostly soak time will be my strategy.
EstorilM
Aug 6, 2014 07:58 AM
john65b
Oct 10, 2013 05:00 PM
blackandtandisco
Feb 12, 2012 09:37 PM
kae
Mar 31, 2011 10:19 PM
Darover
Aug 28, 2007 03:01 PM
