Evap emission error question
Old Sep 2, 2012 | 12:02 PM
robgusto's Avatar
Default Evap emission error question
I have a 2003 Disco throwing an evap emission code. I have replaced the gas cap, I ceared the code and the the check engine light came back on with the same code when I check it with OBD II What next? Is there any way to disconnect the evap sensor to get the dash light off. I am assuming that the evap system (small leak) does not affect performance.
Old Sep 2, 2012 | 12:07 PM
Need the fault code number!!!!!
Old Sep 2, 2012 | 12:11 PM
robgusto's Avatar
Sorry yeah that might help! the code is P0442
Old Sep 2, 2012 | 12:22 PM
So, per the code number you have a small leak which could be anywhere from the tank to the engine compartment and just about needs a smoke test to locate it.
Old Sep 2, 2012 | 12:36 PM
SWAINROVER's Avatar
My 2003 does this to once in a while my code is po441 . I have put a new purge vale and a new gas cap . Usually does this when the Idol get a little rough.
Old Sep 2, 2012 | 02:16 PM
robgusto's Avatar
any ideas on what a smoke test would cost? I'd rather disconnect the sensor if possible, any ideas on if that can be done?
Old Sep 2, 2012 | 03:33 PM
From $60 to $100.
'BamaBoy
Sep 15, 2023 02:29 AM
pixel
May 13, 2011 07:24 PM
bluerover95
Aug 10, 2010 09:17 AM
Dell
May 1, 2009 08:09 PM
savatage
Feb 12, 2007 07:25 PM
