Evap faults and parts that solved the issues
I've been struggling with evap faults setting off the check engine light.
Here are codes I've had and what part replacement solved the issue
P0441 replaced evap purge valve
P1412 and P1415 replaced Solenoid Secondary Air Injection
P0455 replaced the small vacuum line set. This connects the solenoid, intake manifold, SAI filters on each side, the big filter and another part on the rear right of the engine bay. (I'm not sure how to buy a new one, I had one from the engine I swapped in from a P38)
Hope this may help someone else
I tried the Hyundai valve on my ‘03. Would still get P0441 code now and then. Swapped to a Bosch valve and no P0411 code since.
emille26
May 20, 2020 09:19 PM
