EVAP SMOKEDOWN
Old Dec 18, 2008 | 01:49 PM
ryanD2's Avatar
Default EVAP SMOKEDOWN
So I put thesmoke to the evap system today to see if there really is a leak tripping the pesky MIL(p0455). I was really hoping to find smoke leaking from somewhere in the system, but no go. I tested the cap as well, it was good.The Snap on motus wouldnt even comunicate with the truck enough to look for values on the fuel tank pressure sensor. I guess ill just endure the lamp until we get emissions here and then leave it up to LR to fix. Anybody in PA have a LR T4 testbook?
Old Dec 18, 2008 | 06:16 PM
Default RE: EVAP SMOKEDOWN
Remind me what your problem is and what you have done so far.
Old Dec 18, 2008 | 06:21 PM
ryanD2's Avatar
MIL P0455, evap system leak major. Changed gas cap, vacuum/pressure and smoke test system, no leak found...
Old Dec 18, 2008 | 06:25 PM
Do you have a hard time putting gas in?
Old Dec 18, 2008 | 06:32 PM
ryanD2's Avatar
no, full speed till i can hear it just about to climb the neck.
Old Dec 18, 2008 | 06:40 PM
Hum....there is a valve at the carbon canister that will stick and can cause a CEL with a EVAP code, but normally when that happens you have a hard time filling the gas tank.
I suppose if that valve were stuck open it could set off a EVAP leak code.
Old Dec 18, 2008 | 06:46 PM
ryanD2's Avatar
i dunno, without a t4 i cant get the purge and vent solenoids to work by remote to fill it with smoke again and see it it gets past either of those points.
ryanD2
Jun 25, 2009 06:00 PM
saltyrover
Jan 18, 2006 02:26 PM
Bugman
Apr 27, 2005 01:20 AM
Bugman
Apr 26, 2005 12:32 AM
