Everyones favorite codes and why you do not buy reman parts
Old Aug 16, 2017 | 04:55 AM
mln01's Avatar
I don't understand why you think it's the valley gasket that might be causing the problems. The valley gasket is independent of the path air and fuel take into and through the engine. The fuel injector O-rings are the most likely cause for vacuum leaks in the area you are describing.
Old Aug 16, 2017 | 06:29 AM
matt3502's Avatar
Originally Posted by Cj7jed@gmail.com
I have an '03 with the same codes. Replaced MAF, and all 4 O2 sensors with genuine Bosch, still have the codes. I can drive 200+ miles on the freeway before they come back, but they will come back within 5 to 10 miles of city driving. I was about to order an intake valley pan gasket and try that, but your post has me wondering about my brakes as a (partial?) cause. They were getting pretty warn down, so had them replaced, new pads and rotors front and rear. Since then, I have had a few occasions where it almost felt like I was losing the power brakes when I had to step on them hard. (I have a '46 *****'s CJ2A, so I know what that feels like.) Were you experiencing similar issues with your brakes or something different? Also, now they feel like they need bled really bad, even though they didn't before the new brakes were put on.
Thanks for any help from your experience. I still might have to do the valley pan gasket, because when I spray starter fluid on the top rear of the engine, it clearly is sucking it in, and smooths out the rough idle. But if you had symptoms similar to mine and same codes, I might need to do the brake booster as well?
The description of how your brakes were operating is very similar to mine. I replaced all four sets of pads as the rotors looked good. We were very thorough when we bled the brakes, as my buddy who helps me do work on my D2 has OCD.
I got to a point where the braking sucked and the minute I stepped on the brakes it would trip the code, stepping on the brake to go into reverse out of my garage would trip them or on the road. I did notice that I could actually hear a hissing type sound when I stepped on the brakes inside the car, all windows closed.
I too have a bit of a rough idle, but that may be due clogged/old injectors. I do know that once I replaced the BB( both times) the 1171&1174 went away. New BB are a big ticket $500, remans when you can find them are about $275 or so.
I agree with mln01 about the valley gasket.
Old Aug 16, 2017 | 06:37 AM
matt3502's Avatar
Originally Posted by Alex_M
Maybe your buddy over tightened the nuts? I dunno, sounds like a fluke to me.
Alex- I do not think over-tightening was the issue. The nuts we used were the original ones, and the threads on the bolts was clean and the nuts went on without any issues like a hard turn. I really think that lower grade bolts were used when the booster was rehabbed.
My buddy is a very experienced wrench turner and we both check the work. Since my son also drives this beast and our other child rides in very often I don't do work that I think will put them in jeopardy.
Clint Eastwood said it best in MAGNUM FORCE: " A mans got to know his limitations."
Old Aug 16, 2017 | 12:22 PM
Cj7jed@gmail.com's Avatar
Thanks for the info, and sorry for sounding stupid. I must have misunderstood when the guys replying to my thread about these codes suggested it might be the intake manifold gasket (or leaking there).
Is the injector o-ring replacement a huge ordeal, or not too crazy? I see I can get an o-ring seal kit for pretty reasonable price. I have to figure these codes out soon for California smog in a few weeks.
I traced that large plastic vacuum hose from the booster around the back of the engine, to where it clips in the side. Looks like it's in good shape, and the engine dies completely if I pull it out, and runs normal (with a slight miss) when I push it back in.
Lastly, I didn't mean to hijack this thread, and seriously contemplating whether my brake booster is going out like yours was. It just did that thing briefly on the way to work this morning where it felt like I lost power brakes for a second, but only if I hit them hard. Gentle press of the pedal doesn't seem to recreate the scenario.
Thanks again for all the help!
Old Aug 16, 2017 | 12:34 PM
mln01's Avatar
I would take your testing of the vac line a step further. Pull out the line and immediately plug the intake manifold port by putting your finger over it. If the idle smooths out (no missing) that would point to the brake booster. If not, keep looking (e.g injector O-rings).
Old Aug 16, 2017 | 01:06 PM
Thanks for the tips, I'll go try that as soon as I get a break here.
Old Aug 16, 2017 | 01:29 PM
OK, just got a minute to go out and try it. Unfortunately, once it settles down, the slight rough idle seems to be about the same, so pulling that hose and plugging the manifold port doesn't change much if anything.
So first step, I will re-bleed the brakes tomorrow and see if that helps anything.
Second step, still have to chase down these codes. I realize it's money...but this thing has been that from day one, so...should I just replaced the injectors if I tear it all the way down to the point of replacing the o-rings? Not sure how long they're supposed to last, she's just ticked over 90K miles now.
Really appreciate the advice, thank you all.
Old Aug 16, 2017 | 01:33 PM
mln01's Avatar
Bleeding the brakes will never have anything to do with how well the engine runs.
Old Aug 16, 2017 | 01:37 PM
Er...no, sorry for not being specific about that. What I meant was if that will help the brake problem a little, because it only started once we changed the pads and rotors.
I agree there's got to be a vacuum leak or air getting int the system somewhere for those codes, might be the injector seals like you say. Didn't mean to sound like I thought bleeding the brakes had anything to do with that.
Old Aug 17, 2017 | 07:18 AM
matt3502's Avatar
You are not hijacking the thread by any means. You are using it to help solve a problem.
I will say that you almost seem to be looking for a reason to tear into the engine, smog inspection not withstanding. There are some posts about cleaning injectors on here and rebuilding them. You could also go the route of getting rehabbed injectors like these:
*5 YEAR WARRANTY* Genuine Bosch Set Of 8 Fuel Injectors for Land Rover 4.0L | eBay
These are not the only ones out there, just grabbed these as an example.
One thing that just occurred to me is that you may have a brake caliper that is stuck.
If you are not confident in your brake bleeding skills, don't dick around, take it to a shop and get it power bled.
