EXHAUST LEAK AT GASKET
Old Nov 24, 2008 | 08:04 PM
malmberg's Avatar
Default EXHAUST LEAK AT GASKET
I have a 2000 D2 with 100000 miles and on the passenger side of the exhaust there is a leak. I have replaced the gasket from the manifold to the downpipe once before. When I tried to break the nuts loose the entire stud with the nuts came off. Ireplaced the gasket and retighted. It worked great for a couple of months. Then I heard it again. I crawled under and realized that two of the studs were missing. I have reordered all the parts but I was wondering if there is any trick to installing the new studs like using a loctite or something. Any advice would be appreciated. Thank you
Old Nov 25, 2008 | 07:07 PM
Default RE: EXHAUST LEAK AT GASKET
I do not know of any trick to installing exhaust mainfold studs, I would just use a high temp Loc-Tight.
Old Nov 25, 2008 | 08:14 PM
sloppyjoe's Avatar
high temp loctite and the proper torque,,,,
Savannah Buzz
Mar 30, 2017 08:25 PM
Extinct
Sep 10, 2015 09:53 AM
Disco Stew
Mar 28, 2013 09:25 PM
MoShadeTree
Dec 31, 2012 07:32 PM
DuplinDisco
Jan 27, 2008 04:29 PM
