Exhaust leak at SAI tubes
Old Aug 31, 2022 | 02:56 PM
Richard Gallant's Avatar
Default Exhaust leak at SAI tubes
I appear to have an exhaust leak from teh metal sai tubes - checked via vacuum cleaner method. Does this seem reasonable ? Sounds like a y pipe gasket leak and behaves the same quiets with heat
Old Sep 1, 2022 | 06:09 AM
redwhitekat's Avatar
ya they leak, shouldnt be hard to find out where its coming from
Old Sep 1, 2022 | 10:35 AM
Thanks I found it - now to figure out how to fix it - in place ideally.
Old Sep 1, 2022 | 11:55 AM
zski128's Avatar
The copper eventually cracks due to fatigue. I tried braising and high temp JB weld but both didn’t last very long. In the end I replaced it with a used part. I cut the old off but I couldn’t remove the head adapters from the SAI nut so it might be a good idea to have one or two spares.
Old Sep 1, 2022 | 01:01 PM
@zski128 a used bit would be ideal but there are none available here at wreckers. I may try muffler wrap as a temp solution until I can source replacements.
Old Sep 1, 2022 | 07:08 PM
So far so good muffler tape helped a lot, will need to see how it stands up long term
Old Sep 2, 2022 | 10:16 AM
matt3502's Avatar
On Ebay:
https://www.ebay.com/itm/11547714642...Bk9SR_LzqOzfYA
OR this one:
https://www.ebay.com/itm/40374692673...3ABFBM9IO07N9g
Old Sep 2, 2022 | 12:07 PM
Brandon318's Avatar
Assuming the photo is accurate, I'd consider this solid pipe an upgrade: https://www.roverparts.com/fuel-syst...es/WAP500050G/
Old Sep 2, 2022 | 01:53 PM
@matt3503 weird those did not show up for me on my search. @Brandon318 I agree with the solid tubes but not for that price it is about 20.00 of parts and 30 bucks of labour - used to do that kind of work way over priced. I am checking with a local fabricator to see of they can knock something off for me.
Old Sep 4, 2022 | 04:40 PM
matt3502's Avatar
On the ebay search I put in 2004 discovery SAI and those came up. It is EBay USA
