Exhaust leak at SAI tubes
Old 09-05-2022, 11:48 AM
Originally Posted by Brandon318
Assuming the photo is accurate, I'd consider this solid pipe an upgrade: https://www.roverparts.com/fuel-syst...es/WAP500050G/
I had to replace both mine after mangling them.
These pipes from AB are an upgraded style without the corrugated tubing.
Make sure you lube up the nuts with oil when installing.
As well, if you changed out the studs that hold the brackets to bolts, it takes a bit of fitting to get them to tighten down evenly.
The following 2 users liked this post by WildPackofFamilyDogs:
Brandon318 (09-07-2022), Richard Gallant (09-05-2022)
Kadin Wallner
09-06-2020 05:17 AM
samroy92
06-21-2019 04:51 PM
LR03NJ
08-19-2017 08:12 PM
kenk
01-31-2012 12:40 PM
jrm123180
09-29-2010 07:14 AM
Quick Reply: Exhaust leak at SAI tubes
