Exhaust leak at SAI tubes
Old Sep 5, 2022 | 11:48 AM
WildPackofFamilyDogs's Avatar
Originally Posted by Brandon318
Assuming the photo is accurate, I'd consider this solid pipe an upgrade: https://www.roverparts.com/fuel-syst...es/WAP500050G/
I had to replace both mine after mangling them.
These pipes from AB are an upgraded style without the corrugated tubing.
Make sure you lube up the nuts with oil when installing.
As well, if you changed out the studs that hold the brackets to bolts, it takes a bit of fitting to get them to tighten down evenly.
Kadin Wallner
Sep 6, 2020 05:17 AM
samroy92
Jun 21, 2019 04:51 PM
LR03NJ
Aug 19, 2017 08:12 PM
kenk
Jan 31, 2012 12:40 PM
jrm123180
Sep 29, 2010 07:14 AM
