Exhaust manifold bolts Q??
Old Sep 1, 2017 | 05:21 PM
LR03NJ's Avatar
Default Exhaust manifold bolts Q??
Do i have to use anti seize or loctite on the exhaust manifold bolts? Thanks
Old Sep 1, 2017 | 05:24 PM
Friday Night Disco's Avatar
i didn't and no issues
Old Sep 1, 2017 | 05:33 PM
OffroadFrance's Avatar
Preferably install them with a light wipe of engine oil which inevitably will burn off later pn. You never know when you may need to change them later.
Old Sep 1, 2017 | 05:40 PM
mln01's Avatar
Dear God. I'm no expert but I'd never use Loctite on anything in the exhaust system. Exhaust system fasteners are enough of a problem naked.
The RAVE is silent, which means don't use nuthin, but I note that anti-seize is specified for the O2s so why not for the manifold bolts?
A year ago, six years after my headgasket job (I don't recall using anti-seize at the time) I found that the exhaust manifold bolts on the RHS needed to be re-torqued but I'd much rather build that into my regular routine than to not be able to remove a bolt.
Old Sep 1, 2017 | 06:49 PM
LR03NJ's Avatar
I did my HG last november 2016 and the gaskets came with the kit and replaced them that time. The truck sounded like a tank and thought of replacing gaskets. I did use anti seize and probably made the manifold loose. I did use the right torque setting as well.
Old Sep 1, 2017 | 07:12 PM
The Deputy's Avatar
I've used anti-seize most of my life, 40 years of being a mechanic, and never remember a manifold coming loose on account of it. No need to go crazy with the stuff, just a small dab on the threads...and tighten/torque to desired amount. On aluminum engines, I use the silver anti-seize. And use the copper stuff on metal/steel parts.
I'd never, ever use loctite on an exhaust bolt...and have never seen it recommended...especially on an aluminum head.
Brian.
Old Sep 1, 2017 | 07:16 PM
The Deputy's Avatar
Also, I usually flat file the machine surface of the manifold ports. Try and find a file large enough that you can go across at least three of the ports at the same time. Use a straight edge to check your progress. And flat file the exit port too.
Brian.
Old Sep 2, 2017 | 12:39 PM
BackInA88's Avatar
I used anti-seize on mine over 10 years ago and I haven't had a problem.
jayj
Feb 7, 2012 05:05 PM
advntrjnky
Sep 18, 2011 07:56 PM
Disco Alan
May 17, 2011 03:54 PM
Bryan H
Jan 11, 2011 05:56 PM
starcraft1
Jun 12, 2010 11:37 AM
