Exhaust manifold to downpipe gasket
Old Jan 27, 2022 | 08:46 AM
cvhyatt's Avatar
Default Exhaust manifold to downpipe gasket
Anybody using something different for the manifold to downpipe rather than the flat metal gasket? Seems like they son't seal that well.
Old Jan 27, 2022 | 08:57 AM
whowa004's Avatar
if the studs and surfaces are in good shape a fresh gasket should seal good enough. Now any prolonged time with a busted motor mount or excessive vibration may change that. I've found that studs like to work free some and make it impossible to get the nut tight enough. It's a pain but pulling the manifold so you have room to work and pulling the old studs and chasing threads with a tap and new studs fully seated helps a lot.
Old Jan 27, 2022 | 11:00 AM
mollusc's Avatar
Spray the regular gasket with copper coat before you install it.
Old Jan 27, 2022 | 04:14 PM
cvhyatt's Avatar
Originally Posted by TimInNova
I used these and am really happy with them. They are much thicker than the OEM ones.
Remflex 33-001 Exhaust Gasket
i like those but my rover has a single pipe - not double.
Old Jan 27, 2022 | 04:53 PM
tnrangerover's Avatar
X2. No noise from mine in 9 months with copper spray on both sides.
Old Jan 27, 2022 | 04:54 PM
do you have a picture? That's the stock gasket shape.
Old Jan 27, 2022 | 04:59 PM
cvhyatt's Avatar
oh wow you’re right. Not sure what is was thinking.
Old Jan 27, 2022 | 05:27 PM
cvhyatt's Avatar
Is the copper spray the same as the copper anti-seize?
Old Jan 27, 2022 | 05:34 PM
heres a link for ya. It helps get a better seal is all. I believe what it does is fill in micro imperfections. It also helps it stick a bit better if I recall. Last I used it was back in July so my memory is a bit hazy.
https://www.autozone.com/sealants-gl...B&gclsrc=aw.ds
Old Jan 27, 2022 | 05:36 PM
cvhyatt's Avatar
Ordered the remflex and will pick up a can of this copper spray at autozone. Thanks guys!
