Exhaust Manifold Gasket -- What do I need?
Hi guys -- One of my manifold gaskets failed and I'm going to be replacing them. I've looked up the gaskets, but what other parts am I going to need for the job? I assume I'll need the studs as well, but which ones, and is there anything else I should get?
Any help is appreciated!
Since you mention studs I expect the failed gasket is between the exhaust manifold and the downpipe, and not the gasket where the exhaust manifold connects to the the head. The exhaust manifolds are connected to the heads with bolts, not studs.
When i replaced that gasket on my truck 3+ years ago I needed no other parts. I was concerned about the rusted studs but the nuts came off of them with no trouble. I don't recall spraying the studs with PB Blaster before trying to remove the nuts but I may have.
