Exhaust manifold gaskets
Old May 12, 2012 | 02:13 AM
FlyingZebra34's Avatar
Default Exhaust manifold gaskets
Ok, well I'm preparing to remove my entire exhaust system to make some necessary repairs due to several holes in the pipe where someone did some bad welding. (the flange and pipe are separating)
From experience I'm going to buy all new gaskets and just break out the existing bolts and install through bolts because I already know half are going to break when I try to remove them.
Anyhow, for the exhaust manifold, on Atlantic British's site, there are two types. The gasket that is for 2 pipes that is connected via a little strip of metal that doesn't function as a gasket and the one's that are separate gaskets. The separate ones are cheaper and I wanted to know if there was reason behind this madness.
This is the single one - Gasket - Exhaust Manifold - Single Cylinder - 4 Per Side (Part # ERC3606) - Land Rover gaskets and seals from Atlantic British
this is the double one - Land Rover Exhaust Manifold Gasket (Same Fit As Genuine Part # ERR6733)
Old May 12, 2012 | 05:55 AM
vandev's Avatar
Default dual
Its the dual cylinder one..
Chris
twaszak
Jul 15, 2012 07:21 PM
twaszak
Nov 22, 2010 09:26 PM
DiscoIIBrandon
Aug 19, 2010 02:23 PM
brw1982
Jul 21, 2008 11:42 AM
raid13
May 13, 2007 10:22 AM
