Exhaust manifold to Y-Pipe bolts busted...
Old Apr 16, 2023 | 04:50 AM
jamestfl's Avatar
Default Exhaust manifold to Y-Pipe bolts busted...
Got the cats stolen on the truck. Got a new Y pipe and while installing, the short bolts from the manifold to the Y-pipe sheared, some with just enough room to get a nut onto it, but I'm still getting exhaust leak. Best to remove the manifolds, take out the broken bolt thingies, replace, re-attach Y-pipe and go from there???
Old Apr 17, 2023 | 09:52 AM
sqlbullet's Avatar
Yes. And it really isn't that bad. I was really worried when I had to deal with this on mine. Some goober had actually welded the nuts/studs on mine, so I had no choice but to remove and take a cut-off wheel to the "Y" pipe side. The manifolds came off very easy. I had to drill a couple of the studs, but I was able to get them out with minimal fuss. I will confess, I am lucky enough to have a mill, which made this a bit easier, but I could have done it with a hand drill and some swearing.
Good luck.
Old Apr 17, 2023 | 12:04 PM
Richard Gallant's Avatar
Sounds like the guy who owned mine, welded one and screwed up the entire right side exhaust
NVRover
May 12, 2022 09:08 PM
LR03NJ
Sep 2, 2017 12:39 PM
NoBama316
Apr 28, 2014 11:40 AM
slabrat
Apr 15, 2013 08:17 AM
surfoblb
Feb 8, 2011 06:01 PM
