Exhaust Systems for 03 DII
I replaced my muffler and piping from the muffler back. I used a magnaflow muffler. I told the guy at the shop I wanted a mellow tone but not too loud and raspy. It's loud enough to know it has a V8 but mellow to where it doesn't hum or resonate in the cabin. Couldn't be happier. You barely know it has an exhaust when driving. Like I said, you hear it but in no way is is offensive or noisy in the cabin. I have a single oval tip muffler. I'll post a video If I have the time and can figure out how to post it lol.
I just did mine for the sound. Total cost was under $200, and thats because the rear pipe was bent and creased by the previous owner and was choking the flow, so I had it replaced. They have Borla Cat back systems with both single and dual exhaust but they are over $500. If it is just sound you are looking for start with the resonator. If that isn't enough I'd replace the center muffler with a mild magnaflow muffler.
i cut my resonator off, about 1/2 inch behind the resonator, then cut the turndown off the resonator, and clamped it back onto the exhaust, fit perfect over each other, and it was free, took about a half hour to do, and sounded great!!
i just happened to be at Summit Racing in Tallmadge Ohio, and on the clearance rack, they had a Center 2.5" inlet, offset 2.5" outlet, stainless oval muffler, for 40 dollars, instead of the orininal $100, because it had a small dent in it. i cut the old muffler off as close to the muffler as i could get, welded this one on. the new muffler was flatter, but actually about 1" longer than stock, so everything fit back together like a glove, with the pipes fitting into each other. i had to cut off/re-weld the hanger onto the new muffler because it was so close to the old muffler.
i wasnt planning on getting a muffler, but it was on clearance s i said what the heck. i WAS going to go with Borla or Edelbrock SDT, but i couldnt pass up the 40 dollars stainless magnaflow.
AtlanticBritish
Member Group And Special Buys
09-23-2011 09:18 AM
AtlanticBritish
03-01-2011 12:35 PM
RROJ
07-12-2010 09:47 PM
