Expansion Reservior/Tank Leaking...PArts?
Old Nov 7, 2013 | 03:10 PM
ninjabrianv's Avatar
5th Gear
Default Expansion Reservior/Tank Leaking...PArts?
Hey Guys,
03 Land Rover Discovery
I read through a couple write ups on leaky expansion reservoir...my question is where to purchase the replacement parts needed. I read DiscoMike's comment saying to replace the thermostat, reservoir cap, and reservoir which I plan to do but, Looking online I only see replacement reservoirs up to the year 2002? The 2002 reservoirs look the same as far as I can tell and run 23$. The only 2003 reservoir I see is 95$ plus 13$ shipping straight from British Parts Utah. Anyone know if the 2002 reservoir is compatible with a 2003 discovery?
Any help is much appreciated. below are the links for replacement reservoirs
2002 Replacement Reservoir
PCF101410 Coolant Reservoir New Land Rover Discovery 2002 2001 2000 99 1999 | eBay
2003 Replacement Reservoir
Land Rover 2003 2004 Discovery 4 6L Coolant Expansion Tank Reservoir PCF10141 | eBay
Old Nov 7, 2013 | 03:26 PM
ZGPhoto's Avatar
Talk to dusty, he just grabbed one for $35 on rockauto.
Old Nov 7, 2013 | 03:59 PM
dusty1's Avatar
2000 LAND ROVER DISCOVERY Coolant Recovery Tank
I believe all years d2 use the same....someone correct me if I'm wrong
Old Nov 7, 2013 | 04:05 PM
ZGPhoto's Avatar
There are different part numbers, but I've never studied the difference.
Old Nov 7, 2013 | 04:11 PM
5th Gear
pretty sure the reservoirs are the same....thanks guys...I think I've got the one i need ordered! now just need help finding the soft spring 180f thermostat
Old Nov 7, 2013 | 04:12 PM
dusty1's Avatar
rovers north
THERMOSTAT ASSY DII & FREELANDER 180 DEGREES FAHRENHEIT, PEL500110, RNQ028 - Rovers North - Classic Land Rover Parts
Old Nov 8, 2013 | 11:12 AM
5th Gear
thank YOU!!!!!!! MUCHO APPRECIATED!!!!!
Old Nov 10, 2013 | 07:10 AM
Scout_Beagle's Avatar
Don't forget to replace all the factory hose clamps with new worm-screw clamps while you are doing it. It is also a good idea to have a spare [brass preferred] radiator hose bleeder screw on hand, as the original plastic one can become a bit brittle.
I forgot where I got the brass bleeder, but it is a BMW replacement part.
ewatk
Jul 9, 2020 05:17 PM
Beamer1
Sep 1, 2013 06:32 PM
aguison
Nov 16, 2012 09:29 AM
aarongregor
Nov 17, 2011 12:27 PM
