Factory Hose Clamps
Old Sep 1, 2012 | 03:52 PM
Bkreutz's Avatar
Default Factory Hose Clamps
I've read in various posts the factory hose clamps being referred to as "one time usage" and "have to cut them off", so I thought I'd show how the factory clamps can be removed without cutting and they can be re-used (I prefer screw clamps but sometimes the factory ones are easier, especially on vacuum lines and such.
Here's the factory clamp (we've all seen these)
Use a small pocket screwdriver in the slot in the top
Pry the screwdriver toward the clamp and it will pop open
To reinstall, use a normal pair of pliers (or any pair of pliers will work, I use slip joints in the large configuration
Squeeze the clamp together and it will "click"
Hope this is helpful
Old Sep 1, 2012 | 07:58 PM
G Reeves's Avatar
Great pictures and thanks for showing us, If I have to take them off then I will replace them with worm type clips as I dont trust those types
Old Sep 1, 2012 | 08:25 PM
Sweet!
I never knew that, I always cut them off because I thought they were a one time use type of deal, now I know better.
At least with those you know the clamps will be to the correct tightness.
Old Sep 2, 2012 | 06:52 PM
DonRW2007's Avatar
Default They drive me crazy...
Seems like I can never remember the correct way to remove - it's like the first time every time I try to remove one of these. My tendency is to replace with clamps I've known and loved all these years. But, I don't worry about this style popping loose, based on my bad experience with them!
DRW
Old Sep 2, 2012 | 07:53 PM
Antmen's Avatar
*Now* you tell me! Kidding.
Nice post. Thanks!
humroot
Sep 28, 2019 11:07 PM
photocrimes
Mar 9, 2011 12:12 AM
jwfuller
Sep 29, 2007 11:53 AM
werldcup
Mar 14, 2007 05:05 PM
jstreet
Dec 16, 2006 07:44 PM
