Failed MOT on Emissions – What Are My Options?
Old Feb 5, 2025 | 07:24 PM
irontmp's Avatar
Banned
Default Failed MOT on Emissions – What Are My Options?
Hi everyone,
I’m stressed right now because my car just failed its MOT due to high emissions. The garage said it could be the catalytic converter or the exhaust system, but they’re quoting a huge amount for repairs. Has anyone else dealt with this before?
I’m wondering if there’s a cheaper fix or if I should get a second opinion. Also, I’ve heard that using fuel additives or giving the car a good run before the test can help—does that work? I’m on a tight budget, so I’m trying to figure out the best way forward without breaking the bank.
Any advice or experiences you can share would be a massive help.
Old Feb 5, 2025 | 07:26 PM
irontmp's Avatar
Banned
Originally Posted by irontmp
Hi everyone,
I’m wondering if there’s a cheaper fix or if I should get a second opinion. Also, I’ve heard that using fuel additives or giving the car a good run before the test can help—does that work? I’m on a tight budget to book mot peterborough, so I’m trying to figure out the best way forward without breaking the bank.
thanks in advance for any help
Old Feb 5, 2025 | 08:00 PM
LSDisco's Avatar
7th Gear
What did it fail for? Hydrocarbons, NOx, CO? Not really enough information to give a solid answer, could be hundreds of things.
Old Feb 10, 2025 | 01:45 PM
adalton's Avatar
Try a bottle of Cat-a-clean or another form of additive. Might be enough to pass. Here in the states mine failed and I ran a bottle of fuel system cleaner and it passed on the second try.
Old Feb 10, 2025 | 03:48 PM
Harvlr's Avatar
It sounds to me like the mechanic you’re dealing with is just guessing. It might not be difficult or expensive to fix. Guessing at a bad Cat sounds really suspect to me.
Old Feb 11, 2025 | 02:57 PM
CharminULTRA's Avatar
Does your car have any codes?
A leaky exhaust will destroy the cats quickly, it’s probably both.
Old Feb 12, 2025 | 05:07 AM
mln01's Avatar
You don't say what specific diagnostic code(s) was/were present, but the fact that you say your garage said the cause could be the catalytic converter indicates the fault code is either P0420 (Bank 1, left-hand side as viewed from the driver position) or P0430 (the other side).
The fault does indicate a failed catalytic converter, but it could also be a failed oxygen (O2) sensor. The fault is unlikely to appear on both sides at the same time. A sensible diagnostic next step is to swap the O2 sensors from one side to the other. If the fault codes "move" to the other side that would indicate a faulty O2 sensor. If the fault code stays on the same side a failed catalytic converter is indicated. If that's the case, trying one of the quick fixes suggested here by others is a relatively low cost alternative to replacing a catalytic converter.
You don't say where you are located, but your use of the term MOT indicates you may not be in the United States. If you share your location you may find there is a forum member nearby who can help with getting diagnostic codes read.
andino
Oct 18, 2022 05:56 PM
ChicagoRover
Dec 14, 2017 12:05 PM
cammyr01
Feb 16, 2017 07:22 AM
Ross Peeler
Mar 30, 2016 03:04 PM
Racer X
ROAMING WITH FRIENDS
May 12, 2013 08:25 PM
