Fan always on
RE: Fan always on
You need to put what Mike asked for in your signature, or post it every time. Get to be a hassle asking every time.
Your cooling fans come on when your a/c is on, but in your case, you are low on coolant. If you bottle is full, you need to have the system properly bled. I take it when you say you lose heat at stops it means it stops blowing hot air and only blows cold. That is from not enough coolant being circulated through the system. No warm coolant to heat the heater.
